What my plans are for mild perf. gains, please comment/advise/help me decide
Old Jun 17, 2011 | 09:22 AM
sinus19's Avatar
sinus19
damn it aim4squarls! leave something for the rest of us to say!! LOL he's right! that list pretty much says it all.
Old Jun 17, 2011 | 12:49 PM
Jpnorris87's Avatar
Jpnorris87
[quote=neilsrpcustoms;2528957]
Played with the air intake temp, if you make it read about 40deg below ambient, it make a huge improvement towing, but 6-8mpg really stinks.
quote]
How are you getting your intake temp to 40deg below OAT??? NOS??? Are you running your AC evaporator on top of your throttle body?
Old Jun 17, 2011 | 12:50 PM
Put a resistor in the circuit......
Old Jun 17, 2011 | 12:51 PM
aim4squirrels's Avatar
aim4squirrels
You could always suggest an aftermarket ignition.
Old Jun 17, 2011 | 01:11 PM
97tn4x4's Avatar
97tn4x4
as the 318 had flat topped pistons with no reliefs in them.
Not exactly true, I have a 318 that has stock pistons with reliefs in them sitting in my garage floor.
Old Jun 17, 2011 | 03:11 PM
aim4squirrels
If it's a magnum engine, I'm pretty sure it has flat topped pistons, or you have aftermarket pistons.
The 360 has "soap dish" pistons, but no magnum 318s I am aware of had them.
Old Jun 17, 2011 | 05:56 PM
Adobedude's Avatar
Adobedude
Good advice from aim4squirrels, and some advice I've never heard from other members such as the Length of the Kegger intake runners are there to heat up the air and the one that really gets me is that cold air doesn't make more power...I'm guessing that poster has never chased an ET. I loose up to a couple tenths when it get's hot out.
One thing to remember with gears is the 4.10s might get you up and running quicker, but will the added RPMs make you tow with the OD on? That's a no no unless the tranny was built for it.
Old Jun 17, 2011 | 05:58 PM
Adobedude's Avatar
Adobedude
Or not...Stock is plenty if it's in good shape.
Old Jun 18, 2011 | 08:44 PM
CPTAFW163's Avatar
CPTAFW163
very true. The only reason I have a MSD box is because that 6AL used to be in my IROC. I noticed no gain with that ignition....unless you are at WOT, then there is a bit of notice-ability.
MSD has never been the same since they sold out.
Old Jun 18, 2011 | 09:01 PM
I noticed smoother idle, and slightly snappier throttle response when I had the MSD smartbox on my 'bird. I still have it, just don't know if it still works......
