Another guy with an Idle problem.
Old Jun 17, 2011 | 10:09 AM
talthyren's Avatar
talthyren
Default Steam from vents? wtf?
Which sensor? the ECT or the O2?
Old Jun 17, 2011 | 03:01 PM
pitman2's Avatar
pitman2
The O2 sensor.
Old Jun 17, 2011 | 06:35 PM
pitman2's Avatar
pitman2
I replaced the O2 sensor today and, so far so good! I ran a bunch of errands after and it purred like a kitty cat. Thanks for the help guys!
Old Jun 17, 2011 | 08:53 PM
talthyren's Avatar
talthyren
Please start your truck after its been sitting cold for a few hours, overnight if possiblem then start er up and wait 3-4 minutes and see if it does the bad idle...Thats when mines doing it, only when cold and after 2-3 mins of idling...
Im glad you got yours sorted out.
Old Jun 18, 2011 | 01:12 AM
pitman2's Avatar
pitman2
Ok, I'll go do that now.
Old Jun 18, 2011 | 01:22 AM
pitman2's Avatar
pitman2
Just ran it. No problems!
Old Jul 29, 2011 | 08:28 PM
Forceofwon's Avatar
Forceofwon
Default Me too! Amongst other things.....
I too have this problem. When I bought the truck the rear axle locked up, fixed that, replaced front ball joints, and put up with the low/rough idle. Then the other day it got to where it lost power in the heat and I couldnt take off. I took it to an auto repair and they said they couldnt get any readings off the computer, that I need a new one, go to the dealer. I read that can cost 600 bucks on up!! I took off the computer and some of the leads looked correded, so I cleaned everything up and reassembled. I checked the ECM (Computer) with a multimeter and it failed the test. (Put leads on the #1 and #10 pins in the cab. the needle supposed to go to the right and back, but mine just stayed right) Since then I cannot find a computer (ECM) for my truck anywhere! I found some for an automatic transmission-but not a standard tranny.
I have 1995 slt 5.2 liter (318) with 5 speed standard. Anyone know where I can buy a rebuilt or new computer for this???
Old Jul 29, 2011 | 08:43 PM
Seems Jegs still has 'em. (performance PCM. )
