ABS light
Old Jun 17, 2011 | 07:01 PM
SilverSS's Avatar
SilverSS
Default ABS light
My ABS light flashes constantly while driving. I had it hooked up to an ABS code reader and it said intermittent signal rear wheel sensor. I had already replaced the sensor prior to that and I replaced it again after that thinking maybe it was defective. I traced all the wiring and checked all the fuses. Any other ideas as to what would get rid of this light?!
Old Jun 17, 2011 | 07:08 PM
Make sure the connector isn't corroded, and is making good contact.
Make sure the sensor is seated all the way down.
Old Jun 18, 2011 | 12:42 AM
master tech's Avatar
master tech
Site Moderator & Tech
Has there been any repair work done on the rear diff? You could have a tone ring missing or damage tooth on the rear carrier.
Old Jun 18, 2011 | 09:34 AM
SilverSS's Avatar
SilverSS
I changed the fluid a few weeks ago. I recently bought the truck and the light was flashing when I bought it. When I changed the fluid I spun the gears and didn't see anything that looked broken or any missing teeth. I'm not sure what the tone ring is I'll look that up.
