brake pull
Old Jun 17, 2011 | 07:42 PM
bigaaron's Avatar
bigaaron
Thumbs down brake pull
98 Ram 4x4 2500
when brakes applied it pulls pretty good to the left. I changed both calipers and new ceramic pads. Bled the system - gueess what? it still pulls to the left. Any one have a suggestion?
Old Jun 17, 2011 | 08:31 PM
pavement_hater's Avatar
pavement_hater
Check the adjustment on the rear brakes. If one is tighter than the other it can cause a pull.
Old Jun 17, 2011 | 09:00 PM
thetypezero's Avatar
thetypezero
Did you change your rotors as well? May be warped on the back side of the rotor where you cant see it very clearly. My ram was pulling and although my rotors looked fine from the front the rear was faded.
Old Jun 17, 2011 | 09:10 PM
bigaaron's Avatar
bigaaron
i thought a warped rotor makes the pedal pulsate? I guess I could check them with a dial indicator. I did notice when changing the pads on the drivers side inner, it was almost gone. On the outer there was 1/2 life left. THe passenger side had 1/2 life left on both. COuld a bad steering box do this, mine is slooooooppy.
Old Jun 17, 2011 | 09:14 PM
Vtwin92fx's Avatar
Vtwin92fx
With the pad wear, sounds like a bad front brake hose going to the calipers.
Old Jun 17, 2011 | 10:32 PM
Sheriff420's Avatar
Sheriff420
That's what I've heard to be the cause of a pull to one side while braking when the caliper/pads are good.
Old Jun 17, 2011 | 10:56 PM
thetypezero
When was the last time you changed your wheel bearings? And it would be a good idea to get your rotors checked out. Take them to a shop and have them resurfaced. Or spend a little extra and buy new ones
Old Jun 17, 2011 | 11:00 PM
Check your rotors, if they are still thick enough, have them turned. If not, replace them. (and have them turned anyway...... just take a couple thousandths off, to make sure they are true.)
When you have your brakes reassembled, have a buddy step on the pedal, give both front tires a spin. (if you can....) Have your buddy release the pedal, try spinning the tires again. They should both have about the same resistance to turning. If not, replace the brake hose on the sticky side. Bleeding the system out REALLY well wouldn't be a bad plan either.
Old Jun 18, 2011 | 08:52 AM
bigaaron's Avatar
bigaaron
I replaced the majority of the front end parts excluding the track bar which I have. I am going to attack hoses first they are easy and cheap, but the calipers bled fine, plenty of brake fluid volume out of each bleeder - shot it to the inner fender and sprayed all over me LOL! then check rotors. Is there a proportioning valve in this system.
Old Jun 18, 2011 | 08:53 AM
Yep. Sure is, should be right under the drivers feet......
