Releasing pressure on fuel system???
Old Jun 18, 2011 | 12:07 PM
dodgeram07's Avatar
dodgeram07
or just pull the fuel line off(gas will come out) and leave the rails in place save money and time
the longer the truck sits the lower pressure the fuel system will have
the vavle looks just like a vavle stem on ur wheels
Old Jun 18, 2011 | 12:48 PM
Mudshack's Avatar
Mudshack
Got everything off on the keg but the fuel rail and injectors. Any hints on how to pop the injectors out?
Old Jun 18, 2011 | 12:50 PM
Blow the crap out of the holes the injectors go into with compressed air, if you have it..... put a bit of oil in there to lube things up nicely, and then pry on the fuel rail, trying to pull a pair of injectors at a time. Be gentle, as you don't wanna break the fuel rail..... major pain that would be.
Old Jun 18, 2011 | 12:55 PM
Mudshack's Avatar
Mudshack
oil? As in BP Blaster? Or light amount of motor oil??
Old Jun 18, 2011 | 01:00 PM
J415's Avatar
J415
If your doing the plenum, why are you taking out the injectors?
Old Jun 18, 2011 | 01:04 PM
Mudshack's Avatar
Mudshack
So I can pull the entire keg out of truck.
Old Jun 18, 2011 | 01:52 PM
J415's Avatar
J415
Just disconnect the metal clip that has yellow tabs on it. Then pull the fuel line out. You's just creating more work for yourself any other way.
Old Jun 18, 2011 | 02:24 PM
Mudshack's Avatar
Mudshack
I couldn't figure out that metal clip thing, and was afraid of fuel pressure....
Popped the drivers side rail up, and one injector stayed in. I pulled it out by hand and put it back on the rail.
Old Jun 18, 2011 | 02:33 PM
J415's Avatar
J415
The fuel system only builds pressure once you turn the key. That's when the fuel pump hums and builds up pressure.
