95 ram v10 idles rough
Old Jun 18, 2011 | 08:01 AM
ramryan's Avatar
ramryan
Default 95 ram v10 idles rough
well i not giving up yet! truck only has 130k on it. 95 ram 2500 v10 with 5 speed. use to stall after 8-10 miles new plugs, wires, coils and cut off the cats. it runs great now but when coming up to stop sign the rpms drop to where it almost stall and will idles rough.
going to change the IAC valve and install a new battery today and see what happens
any other ideas would be great
Old Jun 18, 2011 | 08:49 AM
Clean the throttle body good too.
Old Jun 18, 2011 | 03:45 PM
ramryan's Avatar
ramryan
UGH!!!! now what? changed the IAC valve, the air filter and a new battery(old battery was 7 yrs old), use almost a whole can of carb cleaner cleaning the TB. and still the same crap, rev it up to about 2k on the tach and it falls in between the 0 and one line above. even when you take it for a ride same results
even unhooked booth O2 sensors on the exhaust
heres whats new
plugs
wires
coils
battery
IAC valve
cats cut off
ECM was sent in, and no problems were found
fuel pump
where do i go next
Old Jun 18, 2011 | 04:14 PM
VEETEN's Avatar
VEETEN
Check your coil packs and the connections to the PCM.
Did you put the Champion copper plugs (OEM)?
Old Jun 21, 2011 | 08:40 PM
ramryan's Avatar
ramryan
well I dont want to jinks it. but i do believe problem fixed!! after i unhooked the negative Battery cable to reset the computer and fixed an exhaust leak it has not dropped under 750 rpms.
i am wonder if an exhaust leak could of been the problem from the start. was leaking at the manifold flange. due to broken bolt. was the o2 sensor getting to much air and was making it run rich so at idle it was flooding it self out. oh well running good now
thanks for everyones help
went from 6mpg pulling 10k trailer to 8.25ish. so it has been all worth it
