Throttle body
Old 06-20-2011, 02:49 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Every dodge 94-01 will have a holley thottle body from the factory. Sad part is theres nothing special about them. There is a couple people that make aftermarket TB's and fastman is probrably the most common.
Talthyren you need to look closer at your throttle body or even look at it and you will see that its a holley tb
Old 06-20-2011, 03:33 PM
Mpi360's Avatar
Mpi360
Mpi360 is offline
Originally Posted by talthyren
They do not come stock with Hollys, yours has been modified.
LMAO! Great tech info from someone who doesn't even know how to change the grease in the diff. A word of advice there bud, buy at least a haynes manual for the basics!
Old 06-20-2011, 05:58 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
http://www.thefastman.com/Throttlebodies5x.asp
I saw most of the improvement on the highway, a little more power at higher speeds. As Dan (the Fastman) states on his page there, 50mm for 5.2L V8s, 52mm for 5.9L V8s. If you plan on building the engine up more later with other parts and a programmer, 52mm would be my recommendation.
Old 06-22-2011, 12:19 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
both the tb's i have are holley one off my 5.9 another off a 5.2 that i scored for 50$ along with the rest of the intake system.
Old 06-22-2011, 03:01 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Holley made the stock TBs. Unfortunately, it doesn't mean anything special. I got excited when I saw it on mine to, about a month after I first bought the truck. After some research, I figured out the same thing you are now... its factory.
Quick Reply: Throttle body
