Steering Column Swap Help
Old Jun 21, 2011 | 11:08 AM
Yep. On/off, a blank with the lite, resume/accel, and set/coast.
Old Jun 21, 2011 | 11:14 AM
ShelbyGT550's Avatar
ShelbyGT550
Yea, Its different then mine, I got no light.
Old Jun 21, 2011 | 11:57 AM
It's just a tiny green dot, on the 'raised' portion of the 'button'. I love my cruise control.....
Old Jun 21, 2011 | 12:11 PM
ShelbyGT550
Yeah, Mine has none, When you press on, on mine it stays pressed until you press off. Still looking for that pinout for the PCM for a 1995/1994 Dodge ram
Old Jun 21, 2011 | 12:23 PM
Ok, wiring diagram is on page 8w 33-2
Old Jun 21, 2011 | 12:32 PM
ShelbyGT550
I want the pinout though for the connector.
Old Jun 21, 2011 | 01:18 PM
Its on the wiring diagram, just gotta kinda decode it.
For the switch: (C211)
Pin 1 appears to be empty.
Pin 2 (resume) goes to the pcm, Connector 135, pin 50.
Pin 3 12 volt power input from junction block, fuse 10. (2 amp)
Pin 4 goes to PCM c135 pin 48
Pin 5 goes to c209, behind the knee bolster.... pin 15.
that would ya need? or am I on the wrong connector?
Old Jun 21, 2011 | 01:34 PM
ShelbyGT550
i need the pin out for the PCM, Not the clockspring :P
Old Jun 21, 2011 | 01:44 PM
Only the two wires go to the PCM.....
Old Jun 21, 2011 | 01:46 PM
ShelbyGT550
I know that, But I still want the full pinout of the PCM. As I am hoping to make up for the differences between the years.
