metalic buzzing sound
Old Jun 21, 2011 | 01:29 PM
talthyren's Avatar
talthyren
Default metalic buzzing sound
99 4x4 1500 5.9 , 150k miles
at about 2k rpm in first gear, and sometimes in second I hear this metallic buzzing sound, Tried to capture it with my phone but it couldn't pick it up.
Sounds like its coming from the front end somewhere, Can hear it with windows up or down.
Its louder when trucks cold, when its warm you can actually barley hear it anymore, Only happens at 2000 RPM, then immediately goes away. The sound is exactly the same every time.
Any ideas?
Old Jun 21, 2011 | 01:46 PM
Loose heat shield somewhere. Check the cat first....
Old Jun 21, 2011 | 01:59 PM
talthyren's Avatar
talthyren
You think it would be a heat shield even though its RPM specific? Cat is brand new, sorry I forgot to mention that.
Does make sense though that it isn't as noticeable when engines warm....Metal expanding...hmmm..
Old Jun 21, 2011 | 02:25 PM
That's what it sounds like from here.... being RPM specific kinda points to it as well, as you get to the correct harmonic frequency at whatever engine speed, and it'll buzz a bit. Check it anyway, and see if anything is sloppy.
Old Jun 21, 2011 | 02:31 PM
talthyren's Avatar
talthyren
Will do, many thanks.
