Fog lights
Old Jun 21, 2011 | 04:29 PM
ronrobbie7's Avatar
ronrobbie7
Default Fog lights
Found a set of aftermarket fog lights that will fit in the factory location and replace my broken ones. The new ones are 55 watt halogens and I was wondering if I could just cut the connector off the factory wiring and splice it in to use the factory switch or does it need to have a relay and be wired to battery? Thanks for any advise
Old Jun 21, 2011 | 04:37 PM
I think the factory guys are only 30 something watts.... if that..... so, what ya may wanna do is, have the factory switch control a relay, that actually powers the lights.
Old Jun 21, 2011 | 05:06 PM
ronrobbie7's Avatar
ronrobbie7
Ok thanks, I'll try to wire them with a relay, dont want any fires
Old Jun 21, 2011 | 09:20 PM
ShelbyGT550's Avatar
ShelbyGT550
I just hooked up a set of fog lights in my 95, and the truck did not come with fog lights so I also bought the OEM switch for it, Then found out it uses a relay as well for the factory fog lights, So I would assume yes, You can just use the factory switch
Old Jun 22, 2011 | 12:51 PM
ronrobbie7's Avatar
ronrobbie7
That would make it easier to just use the factory wiring if out won't hurt anything, maybe I'll try it and check to make sure the switch doesn't get too hot
Old Jun 22, 2011 | 12:59 PM
ShelbyGT550
looks much neater as well imo, i will post some pics later, as i still have yet to do so :P
