Old Aug 4, 2015, 07:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
turbo system for my 5.2L
Old Feb 15, 2012 | 09:14 AM
  #21
sbrodacz's Avatar
sbrodacz
The idea generally with two smaller turbos, as opposed to one larger one is: Less turbo lag. Smaller turbines spin up faster than the large one.
I know turbos pretty well. I had an s2000 that I had built with two different turbo kits. Ran 666 hp on 110 oct.
Now adays with the newer turbos and the new billet wheels you can run a larger turbo with similar lag to a smaller turbo.
Old Feb 15, 2012 | 10:31 AM
  #22
Yeah, the technology has advanced quite a bit since the "good ol' days".
Old Feb 15, 2012 | 10:10 PM
  #23
CPTAFW163's Avatar
CPTAFW163
Here is a good boost read from Marty (Formerly of KRC performance). He had a setup for 4 PSI of boost on a BONE STOCK setup (Stock kegger).
http://www.bionicdodge.com/bionic/in...p?topic=9467.0
RWHP: 308
RWTQ: 354
10 PSI: Holy CRAP!!!! look at those numbers.
RWHP: 413
RWTQ: 504
No intercooler, 110* inlet temp
This was on a rear mount turbo. 2500 for the setup, 60lb FMS injectors, t-76mm, dual 38mm wastegates, crank pulley and shorty headers TUNED BY SCT. So he did not use megasquirt.
That is a pretty flat torque curve for 4 lbs. I would be plenty happy with that cruising at 65 MPH.
Old Feb 15, 2012 | 10:42 PM
  #24
Gotta do stuff to the motor to tolerate 10 pounds of boost though, else, it won't live long.
Old Feb 15, 2012 | 10:58 PM
  #25
CPTAFW163's Avatar
CPTAFW163
But 4PSI!!! You figure if you are going to spend 2500, you can get heads/cam/tune. OR you can spend about 3K and get 4PSI. It would be pretty hard to get 308 RWHP from heads/cam/tune on our trucks as easy as 4 PSI of boost.
10 PSI, I would be getting head studs and a one piece intake. The bottom end can handle it if you don't race it.
However, with 10PSI, you will need a Mega Viper.
Old Feb 15, 2012 | 11:05 PM
  #26
CPTAFW163's Avatar
CPTAFW163
I thought that lag was a testament to not matching the turbo to your application?
Old Feb 16, 2012 | 09:09 AM
  #27
sbrodacz's Avatar
sbrodacz
That is part of it. But no matter what you do a larger turbo is going to have more lag than a smaller turbo no matter what your application is. The new billet wheels helps a lot with lag on the larger turbos.
Old Feb 16, 2012 | 09:58 AM
  #28
Hahns5.2's Avatar
Hahns5.2
Methinks that dyno is a bit optimistic. Although that turbo is pretty large for a stock 5.9, so yeah it'll make nice power at low boost but I think the boost threshold would be relatively high as well, I like getting into boost below 2k.
Headgaskets/bolts, that's about it.
Old Jul 22, 2012 | 12:04 AM
  #29
Srtb8ked's Avatar
Srtb8ked
New Member
im looking to turbo my 1999 5.2 sport i want to run a remote mounted gt35 with inter cooler what do you recommend
Old Jul 22, 2012 | 12:17 AM
  #30
Hahns5.2's Avatar
Hahns5.2
I ran a remote for over 1.5 years, it does work. However I got tired of worrying about oil pump failure and moved to a front mount. I had a "cheap" pump die at 7k and replaced it with a $350 purpose built pump that lasted 29k till I switched. The pump probably would have been fine for a while longer but I hate worrying on long trips, it's not an off the shelf item and it's expensive.
Anyways, not familiar with Garrett part numbers and such but I'd suggest something with a 60-67mm compressor and a T4 P-trim turbine.
I never ran an intercooler on my setup (8PSI) and still don't. My temps were pretty reasonable, however with the front mount I will be installing mater/meth injection next week.
