noise and loss of power
Old Jun 22, 2011 | 05:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
@ mudshack your cat is clogging or clogged! fix,replace or remove, before the work you did on the plenum is a waste and you have a cracked head or two.
And here is the link for wild vents that a simple search would yield.
https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Jun 22, 2011 | 06:37 PM
hydrashocker's Avatar
hydrashocker
Sounds like a bad vacuum check valve for the heater panel.
For the trans, could be a CAT issue for the engine or your something in the trans is loading up. I don't think you have a plenum issue because there is no oil consumption. If you are giving it throttle (WOT) then you will loose vacuum if the check valve is shot. And if the trans is loading up, you are giving more throttle, then you are loosing vacuum hints the check valve.
Old Jun 22, 2011 | 07:45 PM
Mudshack's Avatar
Mudshack
So the check valve replacementeffects the tranny as well as the wild vents? Guess I am still to new to Dodges. Thanks for being patient with me.
Old Jun 22, 2011 | 07:58 PM
zman17's Avatar
zman17
The vacuum leak has nothing to do with the tranny. But it may effect the way the motor runs, which could indirectly effect the operation of the tranny. So fix the known problems first, then move on to the next.
Old Jun 22, 2011 | 08:38 PM
Mudshack's Avatar
Mudshack
Which is?
Old Jun 22, 2011 | 08:48 PM
zman17's Avatar
zman17
I thought you had wild vents too.
Old Jun 24, 2011 | 06:38 PM
chadwall's Avatar
chadwall
Well, still got wild vents. No leaks, guess ill just check the check valves when I get home. Truck would only do it till it got warm after the long drive, then it has stopped making noise and holding rev. Runs like a champ now...
Tried the on off 3 times with key thing and can't get a cel read out.
Was windy and rainy, think its time to change plugs and wires. Plugs last got changed at 80k. Wires never.
Any other tune up ideas?
Old Jun 24, 2011 | 06:43 PM
zman17's Avatar
zman17
You doing the key dance correctly? https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Jun 26, 2011 | 12:50 AM
chadwall's Avatar
chadwall
Ya, guess I'm one of the lucky ones that it doesn't work for.
So problem happened on way home from Oregon, ran great first 450 miles. Stopped at rest stop and wouldn't rev up after that. Flashing cel, then solid. Disconnected battery, cel went away, but still drove home under 60 last 200 miles, except up hill was under 40.. going to autozone to use scanner in the morn.
Old Jun 27, 2011 | 02:28 AM
chadwall's Avatar
chadwall
P0304. Missfire on cyl. 4. So new plugs and wires. Had original wires. 106k miles. Plugs were changed about 80k. So time anyways.
Seems to be fine now. Wires didn't look bad, but just old I guess. Plus when I switched plugs last I used autolites. Went back to champions this time.
Does the wire routing really matter? Like if they touch or cross each other?
