noise and loss of power
I've heard that they can cross at 70-90 degrees, but not run a long next to each other or something. Anyway, I'd follow the re-route TSB on the forum: https://dodgeforum.com/forum/2nd-gen...lug-wires.html
The coil... Is that the thing the wire from cap went to that is by the belt tensioner? If so there was rusty dust fell out when I filled plug. Cleaned and greased along with all plugs.
What's tsp? Didn't do cap and rotor, thought about it, but thought I'd try wires and plugs first.
Do the cap and rotor, and yes, the coil is the thing by the belt tensioner. By the way it sounds, I'd replace that too. Or at the very least clean the connections.
BTW, TPS is the trottle position sensor. I would not worry about that just yet.
