2 hours of AC water drip?
Old Jun 22, 2011 | 11:24 AM
blackbeasst's Avatar
blackbeasst
Default 2 hours of AC water drip?
after only a 5 minute drive to work? i know some is normal, but that doesn't seem normal.....does it?
Old Jun 22, 2011 | 01:27 PM
talthyren's Avatar
talthyren
as long as it is water dripping and not coolant, or some other substance, yes, its completely normal.
Old Jun 22, 2011 | 01:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Could be something clogging the drain, which can be cleared with a piece of wire and time spent under the truck.
Old Jun 22, 2011 | 01:50 PM
redheadhunter21's Avatar
redheadhunter21
are you sure its coming from the AC....because thats a little to excessive
Old Jun 22, 2011 | 01:57 PM
blackbeasst
honestly, no
but it has no color or smell. worse case i'll drive home from work with no air and report back to see if its doing it.
Old Jun 22, 2011 | 02:08 PM
redheadhunter21
You just fixed that hose right......So im guessing you filled up the coolant to the top check your overflow tank and see if you have coolant in there
Old Jun 22, 2011 | 02:11 PM
blackbeasst
correct the lower radiator hose was replaced. yup filled to the top and checked the tank.
Old Jun 22, 2011 | 03:12 PM
corner27's Avatar
corner27
Mine did that the other day as well. I confirmed that it was indeed water and not coolent.
Old Jun 22, 2011 | 05:08 PM
Lukey's Avatar
Lukey
My 1998 does this all the time. First vehicle I've owned with functional A/C--freaked me out the first time I saw the puddle. But it is indeed water and nothing else. I find that it drips for different amounts of time depending on whether I park it on a grade and which way it's facing (facing down a steep grade has the longest drip time).
Old Jun 22, 2011 | 05:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Wow, some one with half a brain around here.
