Need level truck help
I have a dodge ram 4x4 1996 1500 318 .... I have a three inch top gun customz coil spacer and a three inch add a block in the rear but the front is to low how can a raise it up the needed 1-1.5 inch to level her out with out buying another spacer . Can you stack a leveling and a spacer ?Need help soon truck shows a comin
Trending Topics
i wanna thank zman ans spencer and everyone in between for your very very helpful info. i want to try to find coils and control arms even though zman was cheaper i want to stay higher. im new to this a noobv yes to forums so idk what "pm" means or where the sell section is. thanks again my fellow dodgers or dodgies
PM = Private Message. If you click on a members name, there will be a drop down menu, the second option is: Send a private message. There is a notification panel in the upper right, that tells you if you have any new notifications, including PM's, so, when they respond, there will be a bold number there, in place of the zero.
Check out Top Guns Customs for some inexpensive lifts.
