drum brake trouble
Old Jun 22, 2011 | 08:47 PM
trapshooter04's Avatar
trapshooter04
Default drum brake trouble
I have a 97 dodge ram 2500 4x4 that I recently purchased was told it had new shoes and spring kits. About once a week I half to back off the right rear slack adjuster. I have looked at diagrams and compaired both sides and have not found any thing different does any body have a idea.
Old Jun 22, 2011 | 08:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You'll want to confirm that it's not in backwards and that its the correct direction screw thread. It may be tightening every time you apply the brakes in the forward direction, as opposed to tightening when the brakes are applied in the reverse direction.
I'm referring to the adjuster.
Old Jun 22, 2011 | 09:24 PM
trapshooter04
If the adjuster arm should push down on the slack adjuster to tighten it I think it is right.
Old Jun 23, 2011 | 09:33 AM
how do the shoes look? They aren't soaked with 80w90 are they? (gear lube)
Usually, these trucks have just the opposite problem..... have to manually adjust the rears occasionally.
Old Jun 23, 2011 | 09:38 PM
trapshooter04
shoes dry
Old Jun 23, 2011 | 10:36 PM
Does the funny little arm that engages the the adjuster, also hold it in place? Or is it a bit sloppy?
