CEL Again!
Old Jun 23, 2011 | 05:58 PM
Annihilator_X9's Avatar
Annihilator_X9
Default CEL Again!
So I replaced my O2 sensor and reset my PCM. Started up my truck this morning and as soon as I start moving my CEL goes off. I though, the sensor isn't even hot yet so that shouldn't be it
Hooked a scanner up to it and it said "speed sensor output" or something like that which I guess would explain why it lit up as soon as I started moving. Easy fix?
Old Jun 23, 2011 | 06:02 PM
drewactual's Avatar
drewactual
did you by chance jiggle, pull, twist, whatever- on that harness down there while you were pluggin' the o2 sensor in? you may have a bad connection...
but even so.. not too bad.. drop pan, drop filter, swap sensor..
Old Jun 23, 2011 | 06:06 PM
It that sensor even IN the transmission? Doesn't it screw into the side of it somewhere between the trans, and t-case?
Old Jun 23, 2011 | 06:19 PM
Annihilator_X9
I have a leak right in that area too HeyYou.
Old Jun 23, 2011 | 06:22 PM
drewactual's Avatar
drewactual
dang dude.. I get them switched up all the dang time.. the two troublesome ones in the tranny are governor pressure solenoid and, and _______. <- dang, see what I mean?
Old Jun 23, 2011 | 06:29 PM
Annihilator_X9
Drivers side right in front of the TC, right?
Old Jun 23, 2011 | 06:32 PM
I think the 98's still had the sensor in the side of the trans/t-case (whichever) and the harness runs along with the O2 sensor harness.... it might just be loose. have a look, see if you can find the crazy thing, and make sure the connector is in tight.
Old Jun 23, 2011 | 06:51 PM
Annihilator_X9
Thanks a ton! This forum wouldn't be the same without you.
