Bogs until 3K RPM
Old Jun 25, 2011 | 11:19 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Bogs until 3K RPM
So my truck still hesitates until I hit 3,000 rpm. It's gotten incrementally better with everything I've done but something is still not quite right.
Things done: plenum fix, wires, cap & rotor, plugs, O2 sensors.
Things not working: speed sensor
Things I'm going to check next are probably fuel pressure and vacuum.
I doubt it's the cat since it gets better after 2,800-3,000 RPMs. One I hit that range the power is instantly there.
So, sound like a plan to you guys? I'm just kinda throwing things out there.
Thanks!
Old Jun 25, 2011 | 11:30 AM
SpencerS's Avatar
SpencerS
Have you checked your throttle valve cable? Also have you replaced your timing chain and sprockets?
Old Jun 25, 2011 | 11:36 AM
Annihilator_X9
Timing kit is actually on my todo list since my water pump is leaking. Didn't even think that would cause it. Throttle cable looks good. Maybe TPS though. I should look at that too I suppose.
Thanks!
Old Jun 25, 2011 | 11:38 AM
Yeah, definitely take a look at TPS. Also, have you fixed your plenum? Mine was definitely down on power when mine was bad, hitting 3K rpm was like flipping the nitrous switch. Major power difference.
Timing chain and gears also made a great difference in the way the truck ran.
Old Jun 25, 2011 | 12:38 PM
Annihilator_X9
Yeah, plenum is fixed and looks good so far. I also need to replace the PCV Valve for good measure.
Old Jun 25, 2011 | 03:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sorry, but a 98 RAM that had a blown plenum, ALSO has a bad cat.
Old Jun 25, 2011 | 06:24 PM
Annihilator_X9
The cat has been replaced also. OEM but replaced.
Old Jun 25, 2011 | 06:34 PM
Fix the speed sensor.
