Waking up the 360...
Old Jun 26, 2011 | 04:51 AM
S S0DEN's Avatar
S S0DEN
Default Waking up the 360...
1999 Dodge Ram 4 x 4
5.9
New Transmission
What would be your next step in waking up the 360?
I have:
SLP Headers, High Flow Cat, FlowMaster Catback.
Old Jun 26, 2011 | 05:36 AM
97tn4x4's Avatar
97tn4x4
Sct tuner, bigger throttle body, 1.7 hs roller rockers, and wake the truck up in general gears depending on your tire size.
Old Jun 26, 2011 | 09:20 AM
Novarider's Avatar
Novarider
Have you replaced the plenum?
Old Jun 26, 2011 | 02:09 PM
S S0DEN's Avatar
S S0DEN
Negative, stock engine, stock heads, stock intake, stock throttle body, stock injectors.
Old Jun 26, 2011 | 02:12 PM
S S0DEN's Avatar
S S0DEN
The free flowing exhaust has done a good job so far in increasing the performance a bit. But I would think I need to move more fuel through the vehicle since I am moving more air correct? Or is the Throttle Body and Intake restricting the airflow?
Thanks in advance guys.
Old Jun 26, 2011 | 02:22 PM
Adobedude's Avatar
Adobedude
Stock injectors are fine, get a ported TB and tie your mods together with an SCT. How many miles on it? Before you jump into anything involving the valve train, like 1.7s that would be good to know.
Old Jun 26, 2011 | 02:26 PM
S S0DEN's Avatar
S S0DEN
It's a factory crate engine with 60,000 miles on it. I really do not want to get into a cam, lifters and valve train. If that was the case, I would rebuild the 360 I have in my garage and stroke it to a 408.
Can some one point me in the right direction as far as SCT and Throttle Body is concerned? I really do not know what a SCT or even how to order the right unit combined with a Throttle body.
Old Jun 27, 2011 | 10:50 PM
S S0DEN's Avatar
S S0DEN
Whole new fuel system too.
Old Jun 27, 2011 | 11:27 PM
SCT is a programmer for the PCM. You can get them from Hemifever. Best bet would be to call him, have a chat, and have him send you what you need.
You can modify your own throttle body, (poor man's throttle body mod, think there is a DIY in the faq section.....) or, buy one..... not exactly cheap. 52mm to 54mm would be good for your 360.
Old Jun 30, 2011 | 07:02 PM
S S0DEN's Avatar
S S0DEN
Thank you, will do.
