AC problems!!!
Old Jul 1, 2011 | 11:33 AM
  #21
Residual pressure in the line. Nothing to worry about.
Old Jul 1, 2011 | 06:22 PM
  #22
mgaither0's Avatar
mgaither0
So what should I think if the pressure is still at 75. Do u think its the compressor? I also noticed if I put the air on low the air is a little colder the room temperature but still not cold more warmn. Then as I turn the air up the more I turn it up the warmer it is
Old Jul 1, 2011 | 06:26 PM
  #23
Does the compressor run? If the pressure doesn't change at all, either the compressor is toast, or there is a blockage in the system somewhere.
Old Jul 1, 2011 | 06:31 PM
  #24
mgaither0's Avatar
mgaither0
Is there any way to figure out if its blocked ? Any way to clear it out? Any tips to try and get it started. I said before the top line never felt cold. It seemed to be hot the whole time. The bottom only got slightly cold whem I was charging it.
Old Jul 1, 2011 | 06:35 PM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
You need to have it professionally diagnosed. Without the proper equipment you are just pissin in the wind at this point.
Old Jul 1, 2011 | 08:38 PM
  #26
mgaither0's Avatar
mgaither0
Damn it that means more dough lol
Old Jul 2, 2011 | 07:03 AM
  #27
Novarider's Avatar
Novarider
A lot of places will diagnose it for free. They will tell you what's wrong then you decide if you want to spend the dough
Old Jul 3, 2011 | 03:35 AM
  #28
mgaither0's Avatar
mgaither0
Yeah before I even read your response I was thinking that I have seen signs around for free diagnosis on AC at places. I am definitly going to have to check that out.
