Noise from front drivers side
Old Jun 30, 2011 | 08:56 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Noise from front drivers side
I'm thinking U-joint since it only happens while turning. Sounds like a little bit of a squeak and then makes a louder chirping like sound the sharper I turn. Started yesterday.
Figured I'd run it past the collective here.
Old Jun 30, 2011 | 09:02 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Have you run over any hitchhikers or wayward bicyclists lately?
Old Jun 30, 2011 | 09:11 AM
Annihilator_X9
Hmmm.. not that I know of. I'll check for children though since they can fit under there pretty easily.
Old Jun 30, 2011 | 09:12 AM
95BIGRED's Avatar
95BIGRED
ujoint or wheel bearing if you gonna be in there might as well do both. i found wheel bearings on amazon for like 50$ ujoints aren't more than 10$. if you do one side do the other.
Old Jun 30, 2011 | 09:21 AM
Annihilator_X9
Wheel Bearings for $50? Shoot, that's nothing! They're $214 a piece for my Mitsubishi. Damn things are integrated into the hub assembly.
Napa has inner & outer sets for $11-$16 for each. I might pick some up tonight.
Old Jun 30, 2011 | 09:29 AM
Keep in mind, you have pretty much the same setup on your dodge, as you have on your mitsu. Hub/bearing unit. I am not entirely sure if they are rebuildable......
Old Jun 30, 2011 | 09:38 AM
Annihilator_X9
Okay, I'll do the U-Joints first and if that doesn't take care of it then do the wheel bearings.
Old Jun 30, 2011 | 10:01 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Have you tried rotating the lug nuts?
Old Jun 30, 2011 | 11:41 AM
Annihilator_X9
I have not. I'll give it a go.
Old Jun 30, 2011 | 07:54 PM
95BIGRED's Avatar
95BIGRED
is that a graphic on the side of your truck. been trying to figure it out since i saw it.
