exhaust pipe
Old Jul 5, 2011 | 02:38 PM
chadwall's Avatar
chadwall
Ok, so what if I ditched the cat? And do the non fouler thing, for emissions testing they just plug into odb connection. If no check engine light, would I pass?
Old Jul 5, 2011 | 02:51 PM
If there is a visual inspection, you would fail.
Old Jul 5, 2011 | 03:00 PM
chadwall's Avatar
chadwall
So a hollowed cat with the non fouler trick would pass? Maybe some headers and that jegs pipe I seen in another thread with a hollowed cat in there would be good?
Old Jul 5, 2011 | 03:33 PM
The magnaflow hi-flo replacement cat, that also replaces the y-pipe... isn't that much more money, and would be a lot less hassle.... and you would still look pretty stock. Emissions wouldn't be a problem either.
Old Jul 5, 2011 | 03:40 PM
chadwall's Avatar
chadwall
Ok, ill try to find one of those. How restrictive is the stock muffler?
Not too bad, but, as always, there are better ones out there in the aftermarket.
Old Jul 5, 2011 | 03:51 PM
chadwall's Avatar
chadwall
Looking at the magnaflow cat and ypipe, it doesn't look all that less restrictive. Anyone got cut out pics of stock vs magnaflow?
My truck both down tubes run into cat, no y pipe before it.
Old Jul 5, 2011 | 04:24 PM
Its where they hit the cat that they get crunched down.... I think it was Drewactual that cut his apart and had a look, he didn't post pics though.....
Old Jul 5, 2011 | 04:36 PM
chadwall's Avatar
chadwall
I guess if I got headers, off road y pipe, non foulers, and a good muffler and tail pipe exit before tire. I could put the while stock system on for the ten minutes of emissions testing.
Old Jul 5, 2011 | 05:52 PM
chadwall's Avatar
chadwall
But that may be too much work in the winter to swap...
