Removed o2 sensor and smells when running
Old Jun 30, 2011 | 08:39 PM
ShelbyGT550's Avatar
ShelbyGT550
Default Removed o2 sensor and smells when running
Ok, for the hell of it I removed the upstream o2 sensor and started it, it seems to run better then it did before, but I thought it ran good before, o2 sensor is black as tobbies ****, and when I run the truck I am getting this nasty smell (was gagging on it) from the driver side all the way down the truck. Got any ideas? Btw i love the way the truck sounds with the sensor out lol
Old Jun 30, 2011 | 08:42 PM
Justin3's Avatar
Justin3
Your getting the smell of the clogged cat, I assume this is why you took your O2 sensor out in the first place, yeah it smells like rotten eggs but the smell is the least of your concern, now you need to replace that Cat or at least hollow it out.
Old Jun 30, 2011 | 08:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Are you kidding? Put the freakin sensor back in. It only get's removed for a short period of time for troubleshooting purposes.
Old Jun 30, 2011 | 08:47 PM
ShelbyGT550
I am trouble shooting, I am not driving the truck around with it out, my father said a while ago that he was getting exhaust in the cab, as he was showing the symptoms on a 3 hour ride. And please do not jump to conclusions zman.
Old Jun 30, 2011 | 08:49 PM
ShelbyGT550
When I smelled it first it reminded me of raw gas, but it's a little stronger then that. And the reason i pulled the sensor was by a suggestion to check to make sure the cat was not clogged as it seems to be a common issue with these trucks. That and the fact my father smelled exhaust in the cab
Old Jun 30, 2011 | 08:53 PM
ShelbyGT550
Also is it normal for the sensor to be black?
Old Jun 30, 2011 | 09:01 PM
zman17's Avatar
zman17
Of course you'll smell raw gas, the sensor is reading fresh air, so the PCM is dumping fuel into it. Which will also give you the sensation that it's running better.
Old Jun 30, 2011 | 09:10 PM
ShelbyGT550
And the color of the sensor?
Old Jun 30, 2011 | 09:24 PM
zman17's Avatar
zman17
Normal perfect engine would be almost white. If it's black, it might need to be replaced or plenum or tune up, etc...
Old Jul 1, 2011 | 11:29 AM
ShelbyGT550
Looked down the intake and it seems somewhat wet at the bottom, with what appears to be gunk?
