SCT help?
Old Jun 30, 2011 | 11:23 PM
The Codes's Avatar
The Codes
Default SCT help?
So I am going to be etting a sct tuner soon, wanted to know if the tuner has the ability to remove torque management, and reset spedometer for bigger tires or a gear change? also does it read codes? thanks for any advice guys
Old Jul 1, 2011 | 12:14 AM
RamSport97's Avatar
RamSport97
It will remove torque management, it will not calibrate the speedometer, and it will read codes.
Old Jul 1, 2011 | 01:16 AM
The Codes's Avatar
The Codes
is there any other device that you could buy seperately to calibrate the spedometer?
Old Jul 1, 2011 | 01:17 AM
The Codes's Avatar
The Codes
oh also..does removing the t.m. run any risk to damaging any parts?
Old Jul 1, 2011 | 09:16 AM
Annihilator_X9's Avatar
Annihilator_X9
Nope. Torque Management actually does more harm than good on the Transmission.
Old Jul 1, 2011 | 10:20 AM
The Codes's Avatar
The Codes
good to know, thanks
Old Jul 1, 2011 | 10:23 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Good thing you started this thread as I'm considering buying a scanner that will pull codes as well as allow me to adjust & monitor the fuel sync, and other functions. I was curious what people would recommend and some possible sources (in addition to E-Bay).
Old Jul 1, 2011 | 10:42 AM
The Codes's Avatar
The Codes
I am most likely goin to be getting mine from hemifever but I have to get my truck on the dyno for him because of my hughes intake
