New 97 Ram owner, couple of issues
Old Jul 4, 2011 | 05:30 PM
velacreations's Avatar
velacreations
ok, I got the vacuum line all fixed up with tubing, but on a jaunt out today, the vents were acting a bit weird, so I'm going to change both check valves.
I bought an o-ring and put it on the transmission dipstick housing. No leaks, but the truck was acting a bit sluggish at times, so I'm thinking I need to drain the tranny fluid and put in ATF 4+, as it probably doesn't have that right now.
Any thoughts?
Old Jul 4, 2011 | 06:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Somehow I don't think it's your tranny making it sluggish. Read the plenum sticky on top of the threads.
Old Jul 5, 2011 | 01:44 PM
velacreations
oh yikes, that plenum install might be beyond my abilities/time/tools. I'll have to see if I can get a small mirror in there to see if oil is pooling. I will also go ahead and change my PCV, just in case.
Old Jul 5, 2011 | 03:30 PM
Make sure you get one from the dealer.
Old Jul 6, 2011 | 10:19 PM
velacreations
Get the PCV valve from the dealer?
I got one from Autozone, dropped it in, and it doesn't feel sluggish anymore. I also found some vacuum check valves to address my "wacky vents" issue.
I'm hoping I don't have to change the plenum, but I am going to check on it tomorrow with the magnet test, the mirror test, and see what happens.
Old Jul 9, 2011 | 09:54 AM
velacreations
my wacky vents were fixed for a little while, and now they've come back. I'm going to check the new CVs, but I imagine that I've developed a vaccumm leak somewhere.
Another small issue that has popped up. The 4WD light comes on. If I shift into 4WD, then back to 2WD, it turns off, but then will come back on in about 5 minutes or if I turn off the engine. Is this the sensor acting crazy or what?
Old Jul 9, 2011 | 10:56 AM
Either the switch in the cad being weird, or, you have some vacuum lines backwards.
Old Jul 9, 2011 | 03:08 PM
velacreations
do you know to test the CAD switch? And as far as the vacuum lines, could a leak cause the issue? I don't understand the "backwards" comment. How can a vacuum line be backwards?
Old Jul 9, 2011 | 04:51 PM
zman17's Avatar
zman17
This may help, http://www.dodgeram.org/tech/repair/..._engagment.htm
