How to end the ANNOYINGNESS!?
Old Jul 3, 2011 | 04:56 PM
tweav88's Avatar
tweav88
Originally Posted by RamSport97
I just pulled the buzzer module out. If you remove the interior fuse cover, you can see it. It is like 1" wide and 2 to 3" long.
Oh okay, ill try that. Thanks
Old Jul 4, 2011 | 01:04 PM
dhvaughan's Avatar
dhvaughan
on the older models you might can locate and remove the buzzer.
on the new models with the chime, the chime is used for several notifications - including LOW FUEL, LIGHTS ON, and DOOR OPEN. so think twice about removing the chimer from the CTM board .
the cleanest way to do it - all years - is remove the column covers and locate the 2 wire electrical plug at the ignition switch. just unplug it and tape it to the column so it doesn't flop around and rattle.
Old Jul 4, 2011 | 01:52 PM
EndIsNear's Avatar
EndIsNear
Thank you lol. You know you can rewire those wires into the other part of the four prong plug and it'll light up the key switch if you have one capable of doing it. And an led...
Old Jul 6, 2011 | 07:01 PM
king_moaoe's Avatar
king_moaoe
where is the buzzer at?
