Any other ideas what's causing my truck to stall? HELP!
Old Jul 3, 2011 | 03:14 PM
Aerogauge's Avatar
Aerogauge
Default Any other ideas what's causing my truck to stall? HELP!
1996 Dodge Ram 1500 2x4, 318 5.2L V8. Stalls SOMETIMES when I stop, it's intermittent. I have put new: Battery, Distributor cap and rotor, IAC, thermostat, spark plugs. It still stalls sometimes when I stop. please someone give me some other ideas what is wrong.
Old Jul 3, 2011 | 03:17 PM
Remove the throttle body, remove the IAC motor from the throttle body, clean all the crap out of the air passages. (leave the battery disconnected while you do that.) Put it back together, and let it relearn the idle. (sometimes takes a couple minutes.)
Old Jul 3, 2011 | 05:18 PM
tweav88's Avatar
tweav88
Whats the IAC motor? my truck seems like its going to stall sometimes, when i let off the gas at slow speeds it goes down to like 400 rpms
Old Jul 3, 2011 | 05:38 PM
Aerogauge's Avatar
Aerogauge
The Idle Air Control motor, its right on the back of the throttle body
Old Jul 3, 2011 | 06:31 PM
tweav88's Avatar
tweav88
Ohh okay, thanks
Old Jul 3, 2011 | 11:03 PM
fishtownmike's Avatar
fishtownmike
Hello. I had a similar problem recently and diagnosed it to be the Idle air control motor. Went ahead and cleaned the throttle body and the motor to no luck. I still occasionally had the same problem. Never had and diagnostic errors though I had this issue for over a year. Then leaving work one night had trouble starting truck. Stalled three times before it started. This time it threw and error. Just happened to have my code reader under the seat. It was an intermittent cam shaft sensor error. I cleared it and on the way home after exiting the highway it started to sputter then threw another error. I changed the cam shaft sensor and also did the crankshaft sensor just for the hell of it and the truck is running great. I believe your model has the cam shaft sensor but I may be wrong. Just an idea if the trottle body cleaning doesn't work for you....Mike
