01 ram howling ?
Old Jul 5, 2011 | 02:54 PM
ToddzRAM's Avatar
ToddzRAM
Default 01 ram howling ?
Hi need some help here I got a 01 ram 1500 5.9 3 weeks ago now it has new tires on it they are AT not LT on it now when driving it i hear the tire road noise sounds kool but my issue is that i hear like a howling kind loud i think its coming from rear end area but its all new to me nvr had a full size truck so im lost also i noticed thatthe dash RED brake light is on like the parking brake is on brakes seem to be fine and park brake is off any advise ? trying to avoid shops seeing ive been ripped off to much
Old Jul 5, 2011 | 02:58 PM
Check the fluid in your rear differential. Sounds like you have some bearings going out.
Is your ABS light on as well??
Old Jul 5, 2011 | 03:07 PM
ToddzRAM's Avatar
ToddzRAM
ABS light is off just the red BRAKE light is on And would you know how much of a pain to replace the bearings is?
Old Jul 5, 2011 | 03:29 PM
Can be quite the pain.... depending on which ones are bad. Axle bearings aren't too bad, pinion bearings can be fun.... along with the carrier bearings. If it turns out to be pinion, or carrier bearings, you might be better off paying someone else to do it...... If you screw it up, it get can real expensive, real fast.
Check your brake fluid, see if one of the reservoirs is empty. I am thinkin you might have blown the rear brake line.
