Well I've tried for hours to get this ball joint off. I have to replace the upper ball joint for my state inspection and it just wont pop off. Ive beat the pickle fork in for what seems all the way or almost all the way and it didnt even budge. I dont no what to do.
If your trying to separate the U-joints and cant find a stronger friend or bigger hammer. If your trying to press out the ball joints, 1 make sure you are pressing the RIGHT WAY. 2 rent a ball joint press 3 get an impact wrench in there if you can
picture of where your at is worth a million words. If your not willing to search this forum for the 2001 dodge ram service manual atleast pop your phone out take a pic and upload it to photobucket and show us.
heres the link for the service manual if you dont have a digital camera
Mine were stuck pretty good and didn't come out until I went and got a ball joint press. One literally exploded and came out in pieces. Thats how much force the press exerts.
always is less expensive to buy the necessary tools and do it yourself. but something that isn't available in the store is patience, and that is the best tool to get the job done
Check if the ball joint has a little tack weld on it, sometimes they do (but it should break anyway). Use a longer breaker bar or add a pipe to your breaker bar.
