Front axle seals
Old Jul 6, 2011 | 11:57 AM
AFIN's Avatar
AFIN
Default Front axle seals
I need to change the u-joints and seals in my front axle, and I have a couple of questions.
How difficult is it?
Are there any special tools to make the job easier, other than the usual 1/2 drive, and common tools?
Do I need to put friction modifier in the front end, or is that only for the rear?
Thanks
Tom
Old Jul 6, 2011 | 12:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
"sighs"
Old Jul 6, 2011 | 12:11 PM
zman17's Avatar
zman17
http://www.pavementsucks.com/tech-article-3.html
https://dodgeforum.com/forum/2nd-gen...-gen-rams.html
Size:  63.6 KB Available at Quad4x4.com or make your own and do the job over numerous times.
Old Jul 6, 2011 | 04:38 PM
AFIN's Avatar
AFIN
Thanks, I've got the shop manual, but of course it calls for tools I don't have. The pavement sucks and quad 4x4 links were very helpful!
How much of a PITA is it to do? I called the stealership, they want $1200. I can do it myself, would just like to know what kind nightmare I'm getting into.
I've rebuilt motors and trannys before, but never had to mess with axles.
Old Jul 6, 2011 | 05:24 PM
zman17's Avatar
zman17
It's not too awful, just take your time. When you remove the right outer axle, don't lose the plastic bushing that's in the end of it. That bushing is where the outer and inner axles connect.
Old Jul 6, 2011 | 07:21 PM
AFIN's Avatar
AFIN
Ok, thanks!
Old Jul 6, 2011 | 10:39 PM
dhvaughan's Avatar
dhvaughan
IF the big 1-11/16 axle nut comes off.
IF the bearing comes out of the knuckle ok.
IF the front diff comes out of the case ok.
IF you have a tool for pulling the seals into the axle housing....
then its not too bad.
IF any of the above don't come apart like they should, you won't even get to the stupid little $10 seals.
i thought it was a lot of work.
its worth doing, but it might take longer than you expect, and you might need another vehicle to drive back and forth to the parts store.
get good seals - SKF/napa or National/Advance.
get good u-joints - Precision or Spicer.
Old Jul 6, 2011 | 11:07 PM
wardj11's Avatar
wardj11
it took a torch and a long arm it took forever good luck
Old Jul 7, 2011 | 05:32 PM
AFIN's Avatar
AFIN
Should prove to be an interesting weekend project. Thanks
Old Jul 9, 2011 | 10:04 AM
dhvaughan's Avatar
dhvaughan
^^ you can't hide money. LOL
mine -
