magnaflow high flow
Old Jul 6, 2011 | 05:04 PM
stangs13's Avatar
stangs13
Default magnaflow high flow
I know that the direct fit bolts right in to the manifold couplers, but how are Yall getting it attached to the rest of the system after the cat? Will a clamp work? I don't have a welder.
Old Jul 6, 2011 | 05:22 PM
94Beater's Avatar
94Beater
Clamp will do fine. It's 2.5" in diameter.
You might have to find some adapters if it does not fit right in into your exhaust.
I'm actually setting this up this week.
I got the Magnaflow Cat + dual 3" exhaust from Summit.
Old Jul 6, 2011 | 05:56 PM
redneck_ram's Avatar
redneck_ram
that muffler from the 3" dual kit from summit will fall right apart. i have the same one, and the muffler fell apart in less than a year. have since replaced it with a flowmaster 10 series.
to the OP. you may need some adapters, but its not likely. your catback is measured in ID, cat is measured in OD. should slip right on with a bit of persuasion.
Old Jul 6, 2011 | 10:40 PM
chadwall's Avatar
chadwall
Sorry to thread jack, but where are u all finding the high flow direct fit? The direct fits I find on summit, jc Whitney, etc. Do not say high flow.
Old Jul 6, 2011 | 10:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A Magnaflow is a high flow cat.
Old Jul 6, 2011 | 11:09 PM
chadwall's Avatar
chadwall
Well alrighty then. Do they really make a diff if the stock cat is in good shape? Any loss of low end torque?
Old Jul 6, 2011 | 11:12 PM
J415's Avatar
J415
Clamp it on then take it to a muffler shop...they'll charge you about $20
zman17's Avatar
zman17
If you gut your stock one or remove it all together you'll lose bottom end. I had a magnaflow on my 98,no loss of bottom end.
Old Jul 6, 2011 | 11:17 PM
chadwall's Avatar
chadwall
Sweet thanks. I wanna let her breath better and get a little more umph for towing my camp trailer and quads. Just trying to find the best route..
Old Jul 7, 2011 | 02:32 AM
stangs13's Avatar
stangs13
Thanks for the response guys, I'm heading to the local speed shop tomorrow, so ill see if they can just get all of this taken care of for me!
