Compression Test shows bad for Ol' Blue
Old Jul 8, 2011 | 01:31 PM
95RAM360's Avatar
95RAM360
Default Compression Test shows bad for Ol' Blue
well had a chance to do a compression check today...results werent that great.
first cylinder read 90...put oil in cylinder and it read 115
Second cylinder read 95...put oil in and it read 145
i stopped right there because that tells me i need new piston rings.....but cant really complain, the motor has 211,6xx......but whats weird is that the truck runs great, just doesnt have the power it should...has good power, but i know its lacking power.
So i talked to my best friend, and he has a chevy corsica im going to buy for 300 bucks...i looked it all over and it has 1 bad brake line, needs rear shocks and a windshield, which is minor....motor was replaced by the family mechanic who i know personally...and the motor has just about 100K.....
So im going to run that, park my truck at the garage i work at and rebuild her.
my question is would it be worth rebuilding my current motor, or should i take a chance and replace it with one that i found that has 89K, for $500...and obviously swap all my new parts from my motor to the new motor....or just rebuild mine which i know still runs good.
Also ive done some searching for rebuild kits with pistons, crank, cam and all and im finding them for around $1500.....anyone know something thats better in price? i searched hughes, and summit so far, and if im going to rebuild it im doing it right the first time, which is why i want a kit with pistons, cam, crank etc.
this situation sucks, but 'ol blue needs some lovin...and i really really dont want to get rid of her.
what would you guys do if you were in my situation?
Old Jul 8, 2011 | 01:52 PM
aim4squirrels's Avatar
aim4squirrels
You're probably looking at performance parts. Do you really need performance parts?
No reason the crank, cam, and rods can't be reused, they just need a once over and new bearings. If the block needs bored out the pistons can't be reused, but even performance pistons at .030 over are around $425.
Take a look at repair websites, not necessarily at performance websites, unless that's really the route you want to go. If that's the case, open the wallet and bend over, LOL!
Old Jul 8, 2011 | 01:59 PM
95RAM360's Avatar
95RAM360
o i didnt relize it was all performance...i just want to get it right with stock parts...i didnt want the performance route
Old Jul 8, 2011 | 02:03 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
The title confused me. I thought you were talking about this Old Blue:
Old Jul 8, 2011 | 03:51 PM
dodgeboy1979's Avatar
dodgeboy1979
you're ma boy blue!
Old Jul 8, 2011 | 05:18 PM
aim4squirrels
The only reason I could see for not reusing the hard internals is if the motor grenaded on you, and you couldn't trust any of the parts. Otherwise, recycle as much as you can.
Old Jul 8, 2011 | 05:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
WHY? See your next comment.
Huh? Unless you are looking to spend money for no good reason, drive the freakin thing until it blows up. My god, all the body work your truck needs it ain't worth it. Buy another truck with less miles and swap the good stuff from the rust bucket.
Old Jul 8, 2011 | 08:50 PM
OLE BLUE97's Avatar
OLE BLUE97
i thought he was taking about me
Old Jul 8, 2011 | 09:22 PM
Novarider's Avatar
Novarider
If it's running great then why rebuild it?
If you are still not happy you could look over the motor that's $500 and see what you think. Do a compression test on that motor and see what comes up. If it's good then you can swap it for yours. If you go that route you can keep your motor and build it with performance parts or sell your motor to get some money back.
Old Jul 9, 2011 | 08:11 AM
dhvaughan's Avatar
dhvaughan
if its running good - just drive it and don't worry about it.
why spend $300+ on a POS and then another $1000-2000 on a truck that already runs good.
