Wideband A/F with true duals
Old Jul 10, 2011 | 09:29 AM
Buck Slayer's Avatar
Buck Slayer
Other mods such as? I mean are we talkin a lot of serious stuff here?
Old Jul 10, 2011 | 11:17 AM
lazyboy's Avatar
lazyboy
match port intake and heads, larger injectors, larger throttle body, its about balanceing volume in to volume out.
Old Jul 10, 2011 | 11:28 AM
Buck Slayer
Ok well it looks like ill just go with the single 3" exhaust!
Old Jul 10, 2011 | 11:34 AM
Adobedude's Avatar
Adobedude
Either side, doesn't matter...Just follow the directions.
Old Jul 10, 2011 | 11:38 AM
Adobedude's Avatar
Adobedude
Originally Posted by zman17
The right way would be to have an X or H pipe, you install the bung in the center. If you don't have that, then you are stuck to putting it in one side only.
My Dynojet Wideband instructions say to keep it within 30" of the exhaust port...That rules out an H or X pipe.
Old Jul 10, 2011 | 11:44 AM
Adobedude's Avatar
Adobedude
Dual 3's...Bigger is better. Don't buy into the back pressure myth, these things like and need to breathe. And you're set for any future mods.
EDIT: Unless you go with M1, cam, ported heads etc, and have a way to trim fuel...You don't need bigger injectors. On my Dakota I'm still rich with 24's and my list of mods is a mile long....
Old Jul 10, 2011 | 12:05 PM
Buck Slayer
Really? I've always heard that that would be way overkilled!
Old Jul 10, 2011 | 12:17 PM
Adobedude's Avatar
Adobedude
You were asking about Turbos...I'm guessing you have big plans, with Dual 3's, you're set for any mod...And Magnum motors like to breathe, and you must breathe out befor you can breathe in.
I started with Dual 2.5's on my Dakota, went dual 3s...Now I'm upgrading to dual 3.5s. Had I planned for the future, I'd be $$$ ahead.
If all your are doing is exhaust, with no future mods, replace the Y-Pipe (no cat), get a better muffler....Call it good.
If planning on future mods, get some mid length headers, not shorties, and dual 3" pipes with an x or H pipe. 3" Magnaflos are some of the least restrictive mufflers out there...you don't need or want back pressure.
EDIT: I forgot Pacesetter makes some long tubes for a Gen II Ram....Maybe someone will chime in.
Old Jul 10, 2011 | 03:22 PM
zman17's Avatar
zman17
Retired Moderator - RIP
OK, so I won't make that recommendation any more. I just assumed that getting a reading from only one bank is not optimal for tuning and performance wise. But, of course, unless there is one on each side, and the PCM/tuner can differentiate. The point is mute. Of course, if it's in an H or X, the PCM will at least even things out.
Old Jul 10, 2011 | 03:28 PM
S S0DEN's Avatar
S S0DEN
SLP makes a nice set of headers that are not block huggers.
