95 Dodge Ram Shakes at 45-55 MPH
Old 07-11-2011, 05:44 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
snap a pic of that dangling plug and post it. there's something fishy about "a bad muffler that causes NO back pressure." hmm...
Old 07-11-2011, 05:48 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
It's called a clogged cat, LOL
Old 07-11-2011, 06:08 PM
blakeek00's Avatar
blakeek00
blakeek00 is offline
heres the wire i found unplugged. I called a few shops and told them my problem shaking at 45-55 and it stops when i hit the overdrive off button and they siad it might be a transmission problem.
and about the clogged cat I just figured when I replace the muffler I'll drill out the cat as well, will it throw a check engine light since I only have a pre-cat 02 sensor?
Old 07-11-2011, 06:15 PM
blakeek00's Avatar
blakeek00
Photo was too big before here it is
Old 07-11-2011, 06:17 PM
aim4squirrels
Hmm, I don't recognize that particular plug, and you have both trans sensors plugged in by the pic, not much reach for that plug, and it looks factory.
If disengaging the OD unit removes the shutter, then I would say yes, you have a trans problem. more than likely the OD unit is not engaging because the snap ring has broken into several bits and are laying in the bottom of your trans pan. if you pull the pan and find small curved bits about a half inch thick, that's more than likely your problem.
Old 07-11-2011, 06:47 PM
zman17's Avatar
zman17
zman17 is offline
Is there any thing else that does not work?
Old 07-11-2011, 07:33 PM
blakeek00's Avatar
blakeek00
it has a little trouble shifting at 40 as well, if the transmission is the culprit would it even be worth taking in to get fixed? has anyone had or heard of this 45-60 shaking problem with the transmission is it a big expensive problem?
Old 07-14-2011, 03:46 PM
dylan2660's Avatar
dylan2660
dylan2660 is offline
spark plugs for sure just happened to me
Old 07-14-2011, 07:15 PM
dogbosser14's Avatar
dogbosser14
dogbosser14 is offline
Lol, well might as be easy as replacing you tires? are they in bad shape? My truck did the same thing with bad tires, and now its perfect, it can go 120 and not shake. its a beast. But yea do you have bad tires?
Old 07-15-2011, 03:44 AM
JSTMoto's Avatar
JSTMoto
JSTMoto is offline
Does it only shake while under power from the engine? Sounds like this is the case, which would lead me to investigate a power train issue rather than a chassis one.
I propose a simple test to check if whether it's definitely an engine miss or not.
Your goal is to get the engine in OverDrive WITH the Torque Converter locked at the lowest speed possible. When your trans shifts through the gears all the way and goes into TC lockup, just barely ease off the gas until you find it's lower limit before it downshifts.
Once you've done this a few times: while at this speed, slowly apply the gas just a bit to stress the engine WITHOUT downshifting the transmission. You're trying to load the engine.
Now,
Feel the vibrations....
Are they good?
Long live the Beach Boys, now back on topic:
With a touchy foot, I'm able to get my truck down to ~36 mph in OD with the TC locked. At this point, an engine miss was VERY obvious. The locked torque converter carried the miss perfectly. At no other point while driving could I pinpoint a miss. It even idled okay. 'Twas a burned valve in my case.
When you turn off overdrive, the engine will be in higher revs, which can conceal an engine miss. With the engine lugging, the miss will be pronounced.
I'm not convinced that it's a transmission problem just yet....
-JT
Quick Reply: 95 Dodge Ram Shakes at 45-55 MPH
