ABS, Parking Brake, and (!) Lights Go On and Off
My ABS/Parking brake lights have been going on and off for about 5 years now. In my case it's the module which runs about $700 give or take.
You might be lucky and it may just be the sensor which is only around $400.
Pretty pricey to turn off a couple of lights.
Hope it's not the brake line. I just hate bending them or is there an aftermarket line that I wouldn't have to bend?
BRNEYEDGRL80: Do you have any issues with the RWAL or ABS kicking on even though it's dry pavement or anything similar? Or are your lights just on and everything is working fine?
Found this article about bleeding drum brakes and it mentioned that to get the brake light lights to go off you turn the ignition to on and press the brake pedal once. I then turned my truck of and started it. I've stopped it and started it a couple of times today as well as driven it twice and so far my lights have not come back on.
http://www.essortment.com/bleed-brakes-car-57550.html
Never heard of that before. But then again the article also said you must bring your Chrysler vehicle to a mechanic and have it power bled. LOL
Glad its working though, maybe it's a OBDI thing.
