Disable DRL on 2000 Ram pickup
Old Jul 11, 2011 | 10:17 PM
00DodgeQC4x4's Avatar
00DodgeQC4x4
Default Disable DRL on 2000 Ram pickup
I have a 2000 Dodge Ram 2500 4x4 that was Canadian built. It has the DRL on it, and I want to disable them.
I've sent CarGuyOhio a few PMs about the picture in his DIY post (it doesn't come up), but have never gotten a reply from him.
Does anyone have a copy of this picture?
His post is located here;
https://dodgeforum.com/forum/diy-do-...intspirit.html
Any help would be greatly appreciated.
Thanks.
Old Jul 11, 2011 | 10:34 PM
dsertdog56's Avatar
dsertdog56
I'm told you simply pull out the connector plug to the module.
Yeah, it's that simple.
Old Jul 11, 2011 | 11:53 PM
BigRedRam95's Avatar
BigRedRam95
I think you can also just pull the fuse
Old Jul 12, 2011 | 12:27 AM
00DodgeQC4x4
Tried just disconnecting the plugin to the module, but then the high beam indicator doesn't work.
I haven't tried pulling the fuse yet to see what results it brings though.
Old Jul 12, 2011 | 02:08 AM
redheadhunter21's Avatar
redheadhunter21
pull the fuse
Old Jul 12, 2011 | 06:52 AM
Diefenbaker's Avatar
Diefenbaker
There is no Fuse just only for the DRL-Modul.
After unplugging the module you need to connect Pin 6 (red/orange wire) with Pin 3 (red/gray). Now the high beam indicator should work again.
Old Jul 12, 2011 | 03:27 PM
00DodgeQC4x4
Thanks very much Diefenbaker!
Old Jul 15, 2011 | 03:30 PM
00DodgeQC4x4
It worked like a charm....thanks again Diefenbaker! Now the deer and elk won't see my coming as easily during hunting season....
