Pick an engine for me.
Old Jul 11, 2011 | 10:33 PM
Demoes4x's Avatar
Demoes4x
Default Pick an engine for me.
I spun a bearing and had a nasty knock so the engine must be pulled and rebuilt. I was thinking of just replacing it with a new one from a reputable engine builder. I'd like to get something with more HP yet reliable so I'm open for suggestions.
What would you get with a $6000.00 buget
Old Jul 11, 2011 | 11:43 PM
Demoes4x's Avatar
Demoes4x
Would I be able to run a 5.7 HEMI from a 06'
Old Jul 12, 2011 | 12:36 AM
aim4squirrels's Avatar
aim4squirrels
how'd you spin the bearing? revving a little too hard?
5.7 is not an easy change over. I'd say rebuild the 318 as is. Or you could rebuild a JY 360 block for more power, or stroke that 318 to 390ci for a big boost and a grin.
Old Jul 12, 2011 | 12:43 AM
6 grand gives you a lotta options. Might wanna have a read thru Matty675's 408 build thread here.
Old Jul 12, 2011 | 01:09 AM
stangs13's Avatar
stangs13
Summit sells 408 crate engines ready to drop in for a little less than 6...the little cabs left over would be good for whatever goodies you need for it..Idk how the older pcm would work with that though.
Old Jul 12, 2011 | 11:12 AM
InnerCityHillBilly's Avatar
InnerCityHillBilly
this is a good idea but then if the computer dosnt match up that will be even more money, but hell, why not give it a look, why not look at a engine that dosnt have any problems. cause you never know if the engine you would be rebuilding dosnt work and would need more work after bein put back together
Old Jul 12, 2011 | 11:35 AM
stangs13's Avatar
stangs13
Yeah, and all that you would have to do is drop it in and plug it in!! Difficulty level depends on the pcm and whether orvnot it plugs in or not.
Old Jul 12, 2011 | 11:37 AM
What year is the truck?
Old Jul 12, 2011 | 12:52 PM
Demoes4x's Avatar
Demoes4x
It's a 97'
Old Jul 12, 2011 | 01:05 PM
You can spend 365 on a custom tune from HemiFever for that. I think he is about the only one that does 'em for the pre-98 trucks.
