Cold rough idle, misfires until warm
Old Aug 2, 2011 | 01:30 PM
  #21
drewactual's Avatar
drewactual
looking to see if you have a milkshake or not..
  #22
Brent Jones's Avatar
Brent Jones
Just checked oil and its the perfect color and level. The same as when I put it in. Checked the water level also and its perfect.
Old Aug 2, 2011 | 01:43 PM
  #23
drewactual's Avatar
drewactual
sweet... that is a nice little something to not have to worry about, believe me.
Old Aug 6, 2011 | 06:02 PM
  #24
Brent Jones
Well... my problem was all caused by the crankshaft sensor. The first part I replaced because I thought that might be the problem and come to find out I got a bad one from the parts place. Just glad this nightmare is over.
Old Aug 6, 2011 | 06:15 PM
  #25
aim4squirrels's Avatar
aim4squirrels
Awesome, thanks for posting the solution.
Old Jul 19, 2020 | 05:57 PM
  #26
Jonathan Patschke's Avatar
Jonathan Patschke
Originally Posted by Brent Jones
Ok I have a bit of a problem that just came up. 99 Ram 1500 3.9L
Yesterday morning I got in the truck and it was running bad. Misfiring, popping through the exhaust and idling real rough. After about 10-15 minutes it smoothed out and ran fine the rest of the day. So I immediately thought cap & rotor (even though I had replaced them both not more than 1 1/2 years ago). Yesterday evening I replaced both and asked the wife how the truck was doing and she said fine. I took it out for a drive afterwards and no problems at all. This morning I start the truck up and it is doing the exact same thing. Any ideas where to start looking next?
Your problem is the crank position sensor! I all but guarentee it!!- My little Dakota was doing the EXACT same thing and that's what it was!!
Old Jul 20, 2020 | 08:46 AM
  #27
Nine year old thread, and yes, the crank sensor was indeed the problem, as was already posted.......
Old Jul 22, 2020 | 01:53 AM
  #28
Gen2Guy's Avatar
Gen2Guy
Fast way to check for plenum leak is to take off the breather hose going to you air cleaner over the intake....When running at idle a plenum leak will cause a huge amount of vacuum at the end of that hose. Normally there is only slight detectable vacuum there. You will know what I am talking about if you check it..it is very obvious.
