headers?
I am looking for a set of headers for my 96 Ram 1500 4x2 with the 5.9l i really think long tubes are better because they build more low end torque. Am I correct in that? And I heard shorties are a little bit better than stock but I think long tubes are the best.
From a Google search:
If you are making 350 hp or more, and live in a state that allows the use of two-cat H-pipes or off-road H-pipes, then the long-tubes are the header that will make the most power. However, if you have a stock or mildly modified car, live in a state that requires the stock H-pipe, or just want the simplest installation possible, the short-tube would be the best choice.
With that being said...Knowing how much these magnum motors like to breathe...LTs all the way. You're not going to see much with the shorties.
I believe both krc and hughes engines state that long tubes give more power to a 360 all over, regardless.
Before the krc website was dismantled, they had dyno charts claiming to prove it.
When I was going to do headers on my 98 a few years ago, I found and saved this, to help with my decision.
http://www.superchevy.com/technical/...der/index.html
I have long tubes and dint have any loss at all. Putting on longtubes also gets rid if restrictive y pipe . I had to stick to a y pipe because mine is a 4x4 . U could prob do h pipe because u don't have a transfer case . It's worth it
Trending Topics
It isn't about tube length, (though that does play a role) it's more about primary tube DIAMETER when considering headers. Smaller diameter primaries will give more low end, larger diameter is meant more for higher RPM.
I was just saying i didn't have to worry abiut that dumb y-pipe lol
