Banging noise(from driveshaft)
Old Jul 14, 2011 | 12:17 AM
DodgeRam10's Avatar
DodgeRam10
ill have to check if mine is 3 or 4 bolt, also would you suggest replacing the seal and bearing also?
Old Jul 14, 2011 | 12:20 AM
DodgeRam10's Avatar
DodgeRam10
[quote=HeyYou;2549251]That one shows for 98 and up......
It says 88-2000 not 98
Old Jul 14, 2011 | 03:00 PM
My bad. So it does. (that's what I get for posting when I am tired.)
The bearing is huge, and would require some effort to replace, if it isn't damaged, don't worry about it. Seal? Might just as well, you are going to be RIGHT there..... There is also a bushing in there... might wanna have a look at it, and if it looks rough, replace that too. (keep in mind, that feller is pressed in/out..... might have to take it to a machine shop somewhere to have that done.)
Old Jul 14, 2011 | 04:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by DodgeRam10
i found this but i dont know which part # it is, theres 3 different ones. I have a 97 1500
http://www.drivetrain.com/parts_cata...ase_saver.html
What? there is only one TC saver.
And if anyone in the future does a search, and reads this thread. Notice , you do NOT see a 241 transfer case listed. Doesn't matter if it has 3 or 4 or 100 bolts. The TC Saver does not fit or work on a 241 TC.
"Fits: 1988-2000 Dodge, Chevy & GMC NP231, 242 & 243 transfer cases. Will not work on 3 bolt tail housing units."
Old Jul 14, 2011 | 05:14 PM
DodgeRam10's Avatar
DodgeRam10
yea i was looking at the part numbers for the seal and thought it was the tc saver. thanks for being understanding.
Old Jul 14, 2011 | 05:24 PM
zman17's Avatar
zman17
LOL, no prob. I understand how that can be confusing.
