Banging noise(from driveshaft)
Old Jul 13, 2011 | 10:31 PM
tweav88's Avatar
tweav88
Default Banging noise(from driveshaft)
Okay, so occasionally while I'm driving my truck i hear this banging noise when i suddenly take my foot off the accelerator. It sounds like there might be to much play in the drive shaft or something, its only when i suddenly let off the gas, if I let of smoothly it doesn't make the noise.
Is this something these trucks just do or could there be serious problems.
Thanks for any help
Old Jul 13, 2011 | 11:03 PM
DodgeRam10's Avatar
DodgeRam10
my truck does the same exact thing, usually at low speeds like in first gear if i give it gas and let go to stop at a light i hear the clunk. Ive been meaning to write a post but ive been afraid it might be the tranny. Anyways im not sure why but hopefully we can both figure it out, maybe it is a problem with the dodges??
Old Jul 13, 2011 | 11:15 PM
Drop the driveshaft, and check the U-joints. If those seem ok, (well, even if they are toast....) Pull the tailshaft off the t-case, its only three or four bolts... and check the snapring that holds the shaft in place. (should be right against the bearing you will see there.....) My guess is, it isn't there any more. There is an upgraded retainer, called "The Transfer Case Saver" (google it, you will find a source easily) that replaces that snap ring, and is a MUCH better design..... might take a few days to get one, so, just grab a snap ring from the dealer as a temporary fix.
Old Jul 13, 2011 | 11:33 PM
DodgeRam10's Avatar
DodgeRam10
thats what i like to hear... fairly easy and cheap fix
Old Jul 13, 2011 | 11:48 PM
DodgeRam10's Avatar
DodgeRam10
is there a specific site that sells it or should i shop around? I googled it and just found a lot of people talking about it
Old Jul 13, 2011 | 11:52 PM
aim4squirrels's Avatar
aim4squirrels
That or your pinion bearing is going out.
Old Jul 13, 2011 | 11:59 PM
quad4X4 used to sell them, but, they seem to be sold out...... I can't seem to find them on completeoffroad's website..... might wanna call quad, and see if/when they plan to get some more.
Old Jul 14, 2011 | 12:05 AM
DodgeRam10's Avatar
DodgeRam10
i found this but i dont know which part # it is, theres 3 different ones. I have a 97 1500
http://www.drivetrain.com/parts_cata...ase_saver.html
98ramowner's Avatar
98ramowner
this place carries them, and has pics!
Old Jul 14, 2011 | 12:08 AM
That one shows for 98 and up......
I don't see where it even gives you a choice on part numbers...... the chart at the bottom of the page is for the seal, and bushing on the tailhousing, should you decide to replace those as well.
Note that is does NOT fit three-bolt tailhousings as well.
Best bet? Call 'em.
