T.B cleaning
Old Jul 14, 2011 | 09:55 AM
A_POLVADO's Avatar
A_POLVADO
Default T.B cleaning
So I pull the TB off to clean I.A.C btw dirty and gunked up should run alot better. So I decide to adjust the tps check the voltage its at .60v will it really make that big of a difference when i set it to .75v just doesnt seem like that much. I know it helps throttle response but would it be worth the work i have to do to get it to .75?
Old Jul 14, 2011 | 10:38 AM
dsertdog56's Avatar
dsertdog56
Some vehicles respond a bit better many don't.
It didn't help my truck at all.
Old Jul 14, 2011 | 02:51 PM
PCM doesn't care what closed throttle voltage is, to a point...... just so long as it knows what Closed throttle IS. You want to have the battery disconnected while doing your cleaning project, so when you put it all back together, the PCM will re-zero the IAC, and take a cue on what closed throttle TPS voltage is. As long as TPS voltage increases SMOOTHLY from closed, to WOT, what the actual number is, is irrelevant. (for the most part. still has to fall within what the PCM considers an "acceptable" range.)
