Stumped! 5.2 runs rough, backfires then stalls...
Ok, heres what I got. Fall of 09 my show truck started runing like **** for a few weeks then quit while loading it into the trailer. So all I did was roll it into my dads pole barn and sat while I've been building my new garage. Anyways went to fire it up last fall and wouldn't turn over turns out my seal on my fuel cell was bad which alowed water to get in it and burn up the pump and from siting the cylinders locked up from rust. 2 weeks of soaking they freed up. New fuel pump, injectors, fuel rails, cap, rotor, plugs and it still runs like **** so I cut the exhaust off thinking it might be the cat but nope.
As of right now it starts, runs rough backfires then dies. Makes a loud sucking sound through the Tb, I can try to smother the TB but it doesn't die...checked out all vacuum lines, pcv valves, double checked my fuel pressure, pulled and cleaned IAC, did a compression check incase I had a valve sticking (150-160 on all cylinders).
So right now I'm stumped!
How did that work for ya? i have a 00 ram that was doing the same thing, so i pulled the motor and tranny (tranny was out of an earlier year, didnt have OD had to have my old one rebuilt anyways) and now im kinda stumped.. dont really wanna crack the motor open myself, never done internals on a motor before
Re-ran the plug wires for the third time to make sure, new TPS today, tripple checked fuel pressure 43/45 at the fuel pump today (work nights). Starts and idles decent then stumbles and konks out with a hard time restarting. Exhaust is currently out getting ceramic coated right now so could the lack of flow to the O2 be causing this? Gonna replace the crank and cam sensors tomorrow.
PS theres only 36k on the truck.
Trending Topics
Well haven't had any time to work on the truck since I went on 12hr days for work. But I did take it for a ride around the block (open headers and all) she's still sluggish and stalled while costing and under braking. This keeps leading me to think theres a vac leak that I can't find or my plenum gasket went bad??? After it stalls half the time it will start fine the other I have to baby the throttle....I'm so lost!
