4x4 question
Old Jul 18, 2011 | 01:11 PM
1998ram5.9's Avatar
1998ram5.9
Default 4x4 question
Hey is there any way to lock 4x4 with bypassing the actuator. I think i have a vacuume problem or my actuator went. I dont have the money for the posi lock sytem or a new actuator this week and i realy realy need 4x4 for thursday. The fork on the actuator looks good but it has a little side to side play. Can i get under it to lock it in 4x4?
Old Jul 18, 2011 | 01:50 PM
1998ram5.9's Avatar
1998ram5.9
maybe i can make like a home made 4x4 actuator, any ideas?
Old Jul 18, 2011 | 02:12 PM
Why not just find the vacuum leak, and have the system work the way it is supposed to? There are only four lines, one of which is just a vent......
Old Jul 18, 2011 | 02:17 PM
1998ram5.9's Avatar
1998ram5.9
iv looked at all lines and everything looks good. I dont have vacume gage and i realy only need 4x4 for this thursday. Then ill be able to save to buy the posi lock system.
Old Jul 18, 2011 | 02:21 PM
Grab a friend, (one you TRUST. ) sit 'em in the truck, and have 'em start the engine. You crawl under the truck, and disconnect the vacuum lines leading to the CAD. There should be vacuum on the OUTBOARD line, when in 2wd. Make sure you are getting it. (just stick your finger over it, it will be obvious if you have vacuum.)
Have aforementioned friend put the truck in 4wd, (hi or lo, doesn't matter) and vacuum should now be on the INBOARD vacuum line at the cad. If vacuum doesn't switch, might need to replace the switch on the t-case. But, since you wanna go for the posilok anyway...... what you could do is, just run a vacuum line down to the cad, and hook it to the inboard port on the actuator..... so long as the engine is running, CAD would be locked. When you wanna hit the road, and head home, or whatever, just switch the vacuum line to the other side, so it will disengage the front axle.
Old Jul 18, 2011 | 10:17 PM
1998ram5.9's Avatar
1998ram5.9
how do i know which port is inboard and outboard on the actuator?
Old Jul 18, 2011 | 10:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
One is towards the "in" side and the other is towards the"out"side. As a matter of fact, I'm pretty sure I given this link to you in the past.
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Jul 22, 2011 | 07:03 PM
helms's Avatar
helms
There are cable conversion kits too... somewhere.
Old Jul 22, 2011 | 07:05 PM
Posi-Lok.... yeah, they run around 200 bucks though....
Old Jul 22, 2011 | 09:11 PM
98ramowner's Avatar
98ramowner
you can always try making your own posi-lok. here is a write up with pics from jeepforum http://www.jeepforum.com/forum/f12/h...ite-up-595515/
also off topic but is jeepforum affiliated with dodgeforum?
