air conditioner check?
Old Jul 19, 2011 | 10:00 AM
rustynuts's Avatar
rustynuts
Default air conditioner check?
on a 2001, where is the air conditioner fuse located?
would like to check that first. No cold air at all
Old Jul 19, 2011 | 10:25 AM
I think's its in the PDC, under the hood, behind the battery.
Does your horn work?
mac208x's Avatar
mac208x
same in mine, however when i put the ac in something in the engine compartment makes a clicking noise every 10 sec or more.
Old Jul 19, 2011 | 12:38 PM
Tough Ram's Avatar
Tough Ram
the clicking sound you hear is the compressor clutch engaging and disengaging. if it is doing it every 10 seconds then you need an a/c recharge. but if you are low on refrigerant that usually means you have a leak somewhere. most places will charge it for you and put in some dye to try and locate the leak. if you are not getting any cold air try putting it on max a/c and on the coldest setting, then run the engine up to 2000rpm and see what happens.
Old Jul 19, 2011 | 12:52 PM
mac208x's Avatar
mac208x
most likely its low on refrigerant, when i got the truck it bearly had any fluids in it. ill just go get some and see what happens
Old Jul 19, 2011 | 07:51 PM
rustynuts's Avatar
rustynuts
yep my horn works, so that means my AC fuse is ok?
Should I just go and get the AC filled on see what happens?
no cold air at all on any setting
Old Jul 19, 2011 | 08:59 PM
Does the compressor run at all? (as your are standing in front of the truck, looking at the motor, it will be on top of the motor, to your right.) If the clutch isn't engaging, might be a bad switch, or, it might be low on refrigerant. You can jumper the low pressure switch, to see if it is just low on refrigerant. Don't run it very long that way. Just enough to see if it works.
Old Jul 19, 2011 | 09:45 PM
mac208x's Avatar
mac208x
I got refrigerant, empty'd out the old one and put the new one in, the pipe was ice cold for a little than it went warm. the clicking noise is still there, tried the 2000 rpm thing also, nothing. What else can i try? also i got the pressure gauge and each time the clicking noise starts the pressure goes down, and when it clicks again it goes back up.
Btw sorry im in your thread rustynuts but i dont wanna make another thread lolz.
Old Jul 20, 2011 | 12:09 AM
Tough Ram's Avatar
Tough Ram
it is not good to use rifrigerant from autozone or anything like that. you should only put refrigerant in if you have a gauge set and are certified. if you put too much refrigerant in the system you can ruin the compressor. and if you add too much it will make the system run warm and at high pressures and your system will not function properly. best to take it in to a certified shop to have it emptied and refilled. it may be expensive but if you ruin the a/c system you are looking at a minimum of $2000 to replace the parts and thats not counting the labor
Old Jul 20, 2011 | 12:29 AM
mac208x's Avatar
mac208x
i used an expensive one, paid like 50$ for it with the gauge and did not put too much, just like i did it in the instructions plus it was one with seal and oil.
