truck broke today, help please(pics inside)
Old Jul 19, 2011 | 08:34 PM
redneck_ram's Avatar
redneck_ram
Originally Posted by dhvaughan
better order it now, before 5 other people read this thread.
id love too, but i wont have the cash til tomorrow or thursday...... being broke sucks!
Old Jul 19, 2011 | 11:11 PM
JSTMoto's Avatar
JSTMoto
Sounds like your CAD unit locked in while you were driving and your u-joint turned out to be the weakest link!
What were you doing when this happened?
Old Jul 20, 2011 | 12:10 AM
CPTAFW163's Avatar
CPTAFW163
I would get the posi lick, but DHvaughn's posts about the routing troubleshooting made me decide not to.
I still have my truck under warranty until 100K miles or 4 more years. Has 54K now. So i will just keep getting the warranty work. Best $1295 I ever spent. Speaking of which, i have not had my truck back from the shop because of the backlash thing and the battery going kaput. Never thought that warranties covered up to 60 dollars for a new battery. So i got me an OPTIMA!
Old Jul 20, 2011 | 12:39 PM
redneck_ram
i was driving while it happened. it was in 2wd and then i tried cycling the 4wd shifter from 4hi to 2hi to see if it would stop and thats when the drive shaft went bye bye,
going to get the posi lock tomorrow, as well as a new driveshaft thursday. all in all, truck is still drivable, but i still cannot get it into 4lo, and it worked this past winter, so im thinking its time to buy the t-case saver as well.
on a better note, im heading out to go test drive my neighbors 2011 392 challenger srt8!!!
Old Jul 20, 2011 | 01:48 PM
nopower318's Avatar
nopower318
Your pinion looks like its still good, but that u-joint is toast. The posi-lok and a new u-joint and you should be ok. Bet that made one hell of a sound lol.
Old Jul 20, 2011 | 02:46 PM
redneck_ram
yeah one hell of a sound! well that and the whole truck shook like i was on a washboard road. what about my driveshaft? its still good, but the boot that covers the slip joint ripped in about 100 million places. where can i get that boot?
Old Jul 20, 2011 | 02:57 PM
Check the splines where the two parts come together, and make sure the male portion isn't damaged..... (probably pretty trashed....) You would probably be further ahead just replacing it, as it just had a REALLY bad experience.....
Old Jul 20, 2011 | 03:01 PM
redneck_ram
yeah i kinda figured. my local heavy truck shop makes and repairs driveshafts, and they have the boot, but i found a front driveshaft out of a 94 for 50 bucks.
Old Jul 22, 2011 | 03:54 AM
Reddog170's Avatar
Reddog170
Just a quick note, check out your transfer as well. I had a bronco drop a shaft like that and it cracked the transfer across the top. When you put it back together see about getting a catch loop made, this way if for whatever reason it comes apart again it will not jam into the ground. Shaun
Old Jul 22, 2011 | 06:18 AM
redneck_ram
the shaft didnt jam into the ground, the front part of it simply flew off and went flying behind me once the u-joint let go. shaft isnt long enough to hit the ground, the cv-joint at the t-case binds up before it could hit the ground.
