Gears for my 1997
Old Jul 20, 2011 | 04:32 PM
Joey Buentello's Avatar
Joey Buentello
Default Gears for my 1997
i'm running 35's and do 0-60 in 2 weeks. As far as gears go what is reccommended. How big can I or should I go? This is for my daily driver/fishing truck/hunting truck. Havent been hunting in a few years so I'll be doing most of my wheeling at the beach. Was thinking about a rear locker as well.
Old Jul 20, 2011 | 04:41 PM
Ram_King's Avatar
Ram_King
i'd go with 4:10's if your running 35s, for gears id go with yukon.
Old Jul 20, 2011 | 04:48 PM
94Beater's Avatar
94Beater
I got pretty much the same setup
318, 35" tires and am running 4.88 gears - It's not my daily driver though.
But if you don't drive too much I think 4.88 would be just fine.
With 35" tires 4.10 might be too low.
So you're choice is between 4.56 and 4.88.
For me even traveling at 70mph on the freeway, motor is doing about 2600 rpm.
Locker is a different story - it really depends on what you can afford.
I went less expensive (Detroit Locker) route and got Powertrax No-slip locker that installs inside of your carrier.
Hope this helps
Good luck with your project
Old Jul 20, 2011 | 05:53 PM
4.56 will be closest to stock...... 4.88 will give you a bit more bottom end torque. If you do a lot of highway driving, stick with the 4.56.
Old Jul 21, 2011 | 07:01 PM
Joey Buentello
what will my rpms be at with 4.56's on the highway.
Old Jul 21, 2011 | 09:58 PM
Ok, ran some numbers.....
Tire size, gear ratio, RPM @ 70mph
245s (stock?) 3.55, 1889
35's, 3.55, 1646
35's, 4.10, 1901
35's, 4.56, 2114
While the 4.56 seem to put you higher than what you think you want to be, it actually puts the engine higher into the torque curve, so, you get a bit better mileage than you would think.
Old Jul 21, 2011 | 10:27 PM
Joey Buentello
cool 4.56 looks like the way to go. rear locker on the cheap hum?
