Will this bad boy do?
Old Jul 22, 2011 | 02:54 AM
stangs13's Avatar
stangs13
Default Will this bad boy do?
I am interested in putting an underdrive crank pulley on, and I was wondering if this one from summit is something that will work. I am wanting to get a few more things from summit, so I kind of wanted to save on shipping and just order from the same place...I dont want a **** poor made pulley though. http://www.summitracing.com/parts/ASP-504500/
Let me know if I just need to suck the shipping up and order from Hughes or not, thanks!!
Old Jul 22, 2011 | 03:09 AM
redheadhunter21's Avatar
redheadhunter21
Dont see anything wrong with it summit is usually good about not selling crap, and theres not much difference in pulleys, unless your looking at aluminum vs steel
Old Jul 22, 2011 | 10:27 AM
A_POLVADO's Avatar
A_POLVADO
WHAT WOULD YOU EXPECT FROM A U/D PULLEY HP WISE ? TRYING TO FIGURE OUT IF I WANT TO BUY ONE.
sorry for the cap work program requires caps
Old Jul 22, 2011 | 01:57 PM
stangs13's Avatar
stangs13
Different websites say different things as far as HP ratings goes, anywhere from 6-12 ponies.
With this set up I will need the 95.5 inch belt correct?
Old Jul 22, 2011 | 03:23 PM
redheadhunter21
Thats what Im running with mine, make sure you find one or order it before you get all ready to do the work I spent a day driving around trying to find a belt, seems to be the only size every store doesnt have
Its noticeable power, I got mine from ebay and it came with the altenator pulley too but that caused charging problems so Im running just the crank pulley again.
For the price and the 30 minutes it takes to install on the truck I think it was worth it
Old Jul 22, 2011 | 04:12 PM
stangs13's Avatar
stangs13
I just ordered everything else I needed from summit, and the underdrive pulley from ASP racing.
Old Jul 22, 2011 | 05:49 PM
chadhager03's Avatar
chadhager03
How much did it all of it cost?
Old Jul 22, 2011 | 07:03 PM
stangs13's Avatar
stangs13
It was 75 and then whatever tax is..I live an hr from the place so shipping is non existent for me, and he should send it Monday and ill get it Teusday.
Old Jul 22, 2011 | 08:58 PM
4085spd's Avatar
4085spd
http://www.jegs.com/i/March+Performa...10501/10002/-1
That is the pulley iam running. For 36 buck's plus belt i say it is worth it. If i were to spend 80 id get this one.
http://chucker54.stores.yahoo.net/momabipuset.html
It states crank/alt but shows water pump to so id call before ordering. Water pump pulley only works on 97-and down(bolt on pulley vs pressed on). Plus its all aluminum and Mopar mo-parts.
Old Jul 22, 2011 | 11:42 PM
97_DodgeRam's Avatar
97_DodgeRam
Another added question, just to get things straight. I've heard with the undersized drive pulley your top speed goes down, in turn causing you to run higher RPM's while just cruising at highway speeds "50-60" is this true? or not noticable at all really?
