Some issues
Old Jul 24, 2011 | 11:50 AM
offroadjosh's Avatar
offroadjosh
Default Some issues
Went up to a place called red meadow yesterday, and there was stil a loty of snow(that i ended up playing on). The trip was about 200 miles on gravel road and the truck did amazing. Two issues though. Started truck in the am and it fired up fine, but the air bag, brake, and ABS light where on. The radio had no power, theFAns for the AC wouldn't work. Shut it down and re fired and all was well(it has done this 2 or 3 times in the past couple months. Next issue was put truck in low range and when hammering on i, it popped out a couple times(like in to neutral).
Thanks for any ideas guys! Not to worried just curious really.
Old Jul 24, 2011 | 12:54 PM
Sounds like the ignition switch is thinking about giving up the ghost. Check it, see if it is loose, or some such. Might be just that easy. If not, might wanna consider replacing it.
Have you checked the snap ring on the output shaft of your transfer case? Not sure if it would directly cause the issue, but, is definitely worth looking at.
