How rare are 60hds
Old Jul 24, 2011 | 01:42 PM
mj23polaris's Avatar
mj23polaris
Default How rare are 60hds
Jus looked in my glove compartment and read that my 60 is actually a 60hd. How rare are these and wats so different between a 60hd n a 60?
Old Jul 24, 2011 | 03:26 PM
The HD's appear to have had a bit more webbing on the center section, and had the chance to come with 1.5 inch 35 spline axles.........
Old Jul 24, 2011 | 04:07 PM
merc225hp's Avatar
merc225hp
Link to the Dana Spicer book http://www2.dana.com/pdf/X510-5DSD.pdf
Old Jul 26, 2011 | 05:53 PM
mj23polaris
so my trucks is basiclly one ton then???
heres the build sheet
Vehicle Description DODGE RAM 2500 PICKUP
Model Year 2001
Body Model BR 7 L 62
Color PSBA- Bright Silver Metallic Clear Coat
Build Date: October 31, 2000
In-Service Date: January 6, 2001
Sales Code Description
*R1 Premium Cloth 40/20/40 Bench Seat -AZ Agate
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AHD Heavy Duty Snow Plow Prep Group
AHJ Camper Special Group
AJKP Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
A07P 5.9L Engine(EML)/4Sp Auto Trans(DGT)
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CUDP Mini Overhead Console
CUVS Behind Seat Modular Storage System
CUYS Storage Tray
DGBS All 4-Speed Automatic Transmissions
DGT 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHGP Shift-on-the-Fly,241HD Transfer Case
DJFS Dana M60/248MM Front Axle
DMFP 4.10 Rear Axle Ratio
DRDP 200MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EAGC All Gas Engine
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMP Passenger Side Sun Visor w/Mirror
GTSP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAS Hood Insulation
HGBS Dash Liner Insulation
I81S Route 81 - UP, Centreville, IL
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KRXS STRIPE/BADGE/MOLDING/COLOR
KTXS STRIPE/BADGE/MOLDING/COLOR
K1XP STRIPE/BADGE/MOLDING/COLOR
K17P STRIPE/BADGE/MOLDING
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAS Underhood Lamp
LMAS Halogen Headlamps
LNC Clearance Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MUZP SLT Badge
MWDS Removable Tailgate w/Caliper Latches
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKP EVAP Control System
NFVS 35 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PSBA Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TXG LT265/75R16E OWL On/Off Road Tires
TZHP Michelin Brand Tires
WDZP 16X8.0 Forged Aluminum Wheels
WLBP Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
XZBP Increased Rear Spring Stiffness
YAAS Build To U.S. Mkt. Specifications
Old Jul 26, 2011 | 07:01 PM
Nope, just a very heavy duty 3/4 ton.
Old Jul 24, 2012 | 06:05 AM
BLACKSHEEP757's Avatar
BLACKSHEEP757
just my opinion but.........d60/d70 is 1 ton all day long
Old Jul 24, 2012 | 07:23 AM
stewie01's Avatar
stewie01
Take it to scale!
Old Jul 24, 2012 | 10:56 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Whoa.
Someone had a lot of options from the factory. You've got the 7-4 wiring adapter. Duuuuuude.
Old Jul 24, 2012 | 11:52 AM
Wombat Ranger's Avatar
Wombat Ranger
It's a 60/60 though. Hows the tranny build coming Sheep?
Old Jul 25, 2012 | 07:36 AM
BLACKSHEEP757
built and installed ...... put it in saturday.....still havent test driven.....killed hub bearing while doing other bs while it was out.......ordered ball joints,axle u-joints,hub/spindle bearings,etc yesterday for free spin conv......should be back up and smokin by the end of the week.........all of the other parts ive been aquiring for the last few months are on her now.....should feel like a new rig!
